Spot00071.pngSelecting, refreshing, and converting cables
Several cable commands help with quickly selecting cables, refreshing cable data, and converting cables from one type of cable to another or creating a cable from a polyline.
Selecting cables
Command
Path
Select Cables
Spotlight > Cables
To easily select cables in the drawing:
Select the command.
The Select Cables dialog box opens; set the selection criteria.
Refreshing cables
Command
Path
Refresh All Cables
Spotlight > Cables
To update all the cables in the drawing with the values from the Object Info palette, resetting the cable data, select the command. If cable lengths changed, so that a shorter or longer standard cable length is now required, an informational alert opens.
Converting cables
Command
Path
Convert to Cable
Spotlight > Cables
A polyline or polygon can be converted into a cable, or one kind of cable can be converted into a different kind of cable.
To convert to a cable:
1.      Select the polyline or polygon, or the cable to be converted.
2.Select the command.
The Convert to Cable dialog box opens; specify the new cable settings.
Cable tools
Numbering light plot objects
