The ConnectCAD template includes three sheet layers: Schematics, Rack Elevations, and Rack 3D Layouts. These sheet layers already contain viewports which automatically display the associated design layer correctly for presentation. You can edit the scale, rendering, annotations, and so on, as needed. Title block borders are already present and ready to customize. If you create a single, multi-page PDF with the Publish command (Design Series required), arrow circuits become hyperlinks that allow you to navigate from one end of the circuit to the other. Along with the worksheets which report the necessary components, quantities, and other parameters, you have everything you need to present the final project to your client.
