DesignSeries00011.pngCotter pins
Mode
Tool
Tool set
Cotter Pin
Fasteners
The Cotter Pin tool and Cotter Pin - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a cotter pin:
1.      Click the tool and mode.
2.Click to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
