Editing dimensions
Modification
Method
Reference
Edit the parameters of a selected dimension (for example, to change the text offset or to add a note)
Object Info palette or Properties dialog box
Editing dimension properties
●       Format dimension text
●       Delete and edit individual dimensions within a chain
●       Add a dimension to a single or chain linear dimension
Select the dimension, then select the command from the context menu
Editing dimensions with the context menu
Adjust the dimension line, offsets, or text position of a selected dimension
Selection tool
Editing dimensions with the mouse
Customize the markers, text style, and general layout for all dimensions
Create a custom dimension standard
Creating a custom dimension standard
Change the color, line style, or line thickness for all dimensions
Edit the Dimension class
Setting class properties
Change the color, line style, or line thickness of a selected dimension
Attributes palette
Pen attributes
Change the units or precision for all dimensions
File > Document Settings > Units
Units
Edit the precision of a selected dimension
Edit the Prec field from the Object Info palette
Disable associative dimensioning in the document
Deselect Associate dimensions in the document preferences
Document preferences: Dimensions tab
Disassociate a dimension from a specific object
Select the dimension, then select Disassociate from the context menu
Disassociating dimensions
Change adjoining dimensions into a single chain dimension object
Select the dimensions, and then select Modify > Compose
Change a chain object into multiple dimensions
Select the chain, and then select Modify > Decompose
