Geometric dimensioning and tolerancing
noteMode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Geom Dim and Tol Note
Dims/Notes |
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
The Geom Dim and Tol Note tool inserts a notation symbol and text specifying the dimension of round, square, counterbore, and/or countersink holes, and unit ratio for conical and/or flat tapers. Alternatively, a depth symbol and associated text can be inserted.
To insert a geometric dimensioning and tolerancing note:
1. Click the tool and appropriate mode.
2.Click to place the object, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
3.To add a leader and marker, click the Selection tool from the Basic palette and drag the control point on the object. Edit the marker from the Attributes palette (see Marker attributes).
Click
to show/hide the parameters.
