A variety of stage lift labels can be included in the drawing. Text must be entered into the associated field of the Object Info palette for the label to be included.
To select labels for display and format the text:
1. Select a stage lift object. From the Object Info palette, click Text Options.
The Text Options dialog box opens.
2.Specify the text label elements and formatting.
Once the label has been added to the drawing, it can be moved by clicking and dragging the label control point. Click Default Text Position from the Object Info palette of a selected stage lift object to restore the text label(s) to the original location.
