Spot00046.pngInserting speakers
Tool
Tool set
Speaker
Event Design
Use the Speaker tool to insert individual speakers that are not part of an array. Manually-inserted speakers can be placed as single speakers, or as several speakers arranged in a column. A variety of supports and labeling options are available.
Mode
Description
Insert by Symbol
Inserts a speaker symbol from the resource library; symbol resources include preset data and detailed geometry for visualization, but respond more slowly to edits such as rotating the object
Insert by Catalog
Inserts a speaker from the speaker catalog; catalog resources include preset data and a basic box of the correct size to respond quickly and efficiently to edits such as rotating the object
Speaker Symbol
(Insert by Symbol mode only)
Click to select a resource from the Resource Selector
Catalog Item
(Insert by Catalog mode only)
Click to select a speaker with preset data from the catalog
Alignment modes
Defines how the speaker is aligned on insertion; see The Symbol Insertion tool
Preferences
Sets the default parameters for the speaker
To insert a speaker:
1.      Click the tool and modes.
2.Do one of the following:
●       For Insert by Symbol mode, click Speaker Symbol on the Tool bar to select a resource from the Resource Selector.
●       For Insert by Catalog mode, click Catalog Item on the Tool bar to select a speaker with preset data from the catalog.
●       To create a custom speaker, click Preferences to open the object properties dialog box and specify the tool’s default parameters; set the Source to Catalog and Type to Generic, and then enter the parameters. The speaker can be saved to the catalog from the Object Info palette after placement.
3.Click to place the object, and click again to set the rotation.
Depending on the insertion method used, some parameters are automatically populated and disabled, and others can be edited later from the Object Info palette.
Inserting speakers and speaker arrays
Formatting speaker object labels
Inserting speaker arrays
Concept: Attaching loads to rigging objects
