Setting
the image on the video
screenSelect an image to display on the television, video screen, or LED screen. The Vectorworks Spotlight product includes a number of sample images, or you can create your own textures. Textures must use an image color shader with constant reflectivity to display on the video screen (see Creating textures).
If the Vectorworks file is intended for Exporting to Vision, associate a video source with the screen, for video display during visualizations.
To set the video screen image:
1. Select a television, video screen object, blended screen, or LED screen object. From the Object Info palette, click Edit Screen Image or Edit Array Image.
The Edit Screen Image or Edit Array Image dialog box opens.
Click
to show/hide the parameters.
2.If needed, adjust the image scale, and shift the image horizontally or vertically until it appears correctly in the preview.
