Editing
drainsMode |
Tool |
Tool set |
Edit
Slab Drainage
Building Shell |
Drains can be edited and deleted using context menu commands that are available when the Slab Drainage tool is selected.
To edit drain properties:
1. Select the slab object.
2.Click the tool and mode.
3.Right-click on one or more drains and select Edit Drain(s) from the context menu.
The Drain Settings dialog box opens.
4.Set the properties.
Click
to show/hide the parameters.
To delete a drain:
2.Click the Slab Drainage tool.
3.Right-click on one or more drains and select Delete from the context menu.
