Command |
Path |
Import mtextur |
File > Import |
An mtextur texture can be imported into Vectorworks as a Renderworks texture and/or an image file. Many of the textures have the reflectivity, transparency, and bump shaders needed for a detailed Renderworks texture. When additional information such as manufacturer name, and so on is available in the mtextur resource, this information is included as a searchable tag in the Resource Manager for the imported Renderworks texture and/or image file.
Imported Renderworks textures can be adjusted as needed by Editing textures and shaders.
Internet access is required to import mtextur textures.
To import an mtextur texture as a Renderworks texture or an image file:
1. Select the command.
An Import mtextur web browser opens.
The Import mtextur Settings dialog box opens.
Click
to show/hide the parameters.
3.Select the settings and click OK.
4.Use the mtextur filters and search function to locate the resources for download.
5.For the selected mtextur resource, click CAD- & BIM-TEXTUR to download.
6.If Automatically close the “Import mtextur” dialog after download is deselected, click Close after you have selected all the resources needed.
The textures/images downloaded are available in the Resource Manager for the current file; the last resource downloaded is active.
