Placing irrigation controllersTool |
Tool set |
Controller
Irrigation |
The Controller tool places an irrigation controller object, representing the electronic devices that are programmed to control valves. Controllers with parameters from a selected manufacturer are available, or a controller can be placed as a custom controller with parameters that can be specified after placement. Controllers do not connect to irrigation networks.
To place a controller on the drawing:
1. Click the tool.
2.Click Controller on the Tool bar to select a resource from the Resource Selector. Select from one of the manufacturer libraries, or select the custom resource from Custom.vwx and set its properties after placement. The parameters can be edited later from the Object Info palette.
3.Click once to place the controller.
Click
to show/hide the parameters.
