Command |
Path |
Lighting Symbol Maintenance |
Spotlight > Reports |
Manage, edit, and update the symbols and data for all the lighting symbols in the file from a single location. Easily spot inconsistencies and missing data, and fix the issues for all existing symbols or just for future symbol placement.
A lighting device whose symbol definition cannot be located will display with default geometry, until a replacement symbol is assigned.
To maintain the data and symbols for all the lighting symbols in the file:
1. Select the command.
The Lighting Symbol Maintenance dialog box opens.
Click
to show/hide the parameters.
2.If any lighting device data has changed, but Update all lighting devices is not selected, an alert message displays when you click OK.
Click Yes to update all existing and future symbol instances in the file. Click No to update only future symbol instances.
