Adding text to a databaseCommand |
Path |
Add Text to Database |
Text |
Text objects can be added from the drawing to a selected database. This is convenient for retrieving text from older, converted files for use with the Notes Manager or when adding frequently-used text to a database for easy future insertion as an annotation.
To add drawing text to a database:
1. Select the command.
The Add Text to Database dialog box opens. Specify which text objects to select and indicate in which databases to search for duplicated text.
Click
to show/hide the parameters.
2.Click OK. If any of the text is not found in the text search database(s), the Notes Manager: Add Text to Database dialog box opens.
The left side of the dialog box is the same as the general Notes Manager; see Managing database notes. The right side of the dialog box displays the list of text available to add.
3.From the Text to Add list, select a note. The current text of the note in the drawing displays in the Note Text field on the right side of the dialog box.
4.Do one of the following:
● Select a current database entry and click < Update to replace the database text with the note text from the drawing.
● Select a database section and click < Add to add the drawing note text as a new database entry in the section.
