DesignSeries.pngEditing keynote callouts and the keynote legend
Both the keynotes and keynote legend can be edited after placement. To edit a single keynote, select it and make the changes from the Object Info palette. To edit all the keynotes associated with a particular keynote legend, select the keynote legend and make the edits from the Object Info palette.
The keynotes bubble style can also display in the keynote legend; control the style with either the keynotes or the legend.
Editing keynotes
       Edit the text or graphics of an individual keynote the same as a callout; see Editing a callout object.
       To convert an existing keynote into an ordinary callout object, deselect Place As Keynote from the Object Info palette. The keynote is removed from the keynote legend.
Deleting keynotes
If you delete a keynote, the remaining keynotes are not renumbered. The keynote legend maintains a “gap” or placeholder displaying the custom text specified in Unused Position Text. However, if Re-use Unused Positions is selected and another keynote is placed in the drawing, the new keynote replaces the first “gap” keynote. Clicking Remove Gaps from the Object Info palette of a selected keynote legend also removes gaps; another way to remove gaps is to sort the keynotes in the Keynotes List dialog box.
Editing the keynote legend
Edit the keynote legend parameters from the Object Info palette.
The keynote legend contains control points for adjusting the hanging indent and text width directly from the drawing.
To change the text or numbering of multiple keynotes:
Select the keynote legend and click Edit Notes from the Object Info palette.
The Keynote List dialog box opens.
Inserting callouts or keynotes
Notes management
