Aligning and distributing objects
Aligning and distributing objects in the screen plane
Command
Path
Shortcut
Align/Distribute
●       Modify > Align
●       Context menu
●       Ctrl+= (Windows)
●       Cmd+= (Mac)
The Align/Distribute command aligns and distributes multiple objects in the screen plane. Alignment and distribution are based upon the vertical and horizontal axes, relative to the screen.
To align/distribute objects:
1.      Select the objects to be aligned/distributed.
2.Select the command.
Alternatively, right-click on the object to serve as the alignment reference. The alignment reference is locked into place, and the other selected objects are aligned relative to it. Select Align/Distribute from the context menu. The most common align and distribute commands display on a flyout context menu. Select the desired command, or select Align/Distribute to open the Align/Distribute Objects dialog box.
The Align/Distribute Objects dialog box opens.
3.Select the alignment/distribution criteria. Objects are only moved along the horizontal and vertical axes.
The program aligns/distributes the selected objects.
Loci and locked objects are special objects and behave differently when present during an alignment/distribution operation.
If a locus point is one of the selected objects, all objects are aligned relative to that locus. If there are multiple loci in the selection, then the loci are aligned/distributed like any other object.
Locked objects in a selection do not move. Other objects are aligned/distributed relative to the locked objects.
Aligning and distributing objects in 3D
Aligning objects to grid
Aligning and distributing leader lines
