Preset rotation angles
Command
Path
Rotate
●       Modify
●       Context menu
The rotate commands provide a number of ways to rotate objects in the screen plane without changing their base location in the drawing. Select one of the preset rotation angles, or specify a custom rotation angle.
To rotate at a specified angle:
1.      Select the object to rotate.
2.Select the command, and then select one of the pre-set rotations.
Rotating objects
