Adding plants to the plant catalogFrom the Select Plant Data dialog box, opened when Accessing the plant catalogs, plants can be added to the currently selected plant catalog. The plant data can be obtained online (internet access required) or from another local plant catalog. Once online data has been downloaded, it is available offline; however, images require an internet connection to display. Local catalogs are always accessible; if an internet connection is not available, previously accessed online catalogs display the most recently synced data.
To add plants to the current plant catalog:
1. From the Select Plant Data dialog box, select the plant catalog for the new plant.
2.Click Add.
The Add Plant dialog box opens.
Click
to show/hide the parameters.
3.Choose the plant’s source from the Select the plants to use list. Both local and online lists are available, depending on internet connectivity.
4.Select the plant to add. If images are available, they may take a moment to download temporarily for display.
5.Click OK to add the selected plant or plants to the plant catalog, and return to the Select Plant Data dialog box.
The plant data and any images are downloaded to the user folder.
