Land00057.pngCreating plant styles from the plant catalog
Command
Workspace: Path
Create Plant Style from Catalog
●       Designer: AEC > Plants
●       Landmark: Landmark
Individual plant styles can use data from plant catalogs as described in Accessing the plant catalogs. It would be tedious to create many plant styles based on data one by one; therefore, plant catalog data can be used to automatically create plant styles.
To create one or more plant styles based on plant catalog data:
1.      Select the command.
The Create Plant Style from Catalog dialog box opens.
2.Select the plant or plants to be used as the basis of the new plant styles by clicking in the Use column. A check mark indicates that the plant will be used to create a plant style.
3.Select each plant and set any plant style options that will apply to the style that is created. Basic options are available from the dialog box; click More Plant Style Settings to set less common plant style options. All of the plant data from the selected plants are, of course, added to the plant style automatically.
4.Click OK to create a plant style based on each selected plant. The plant styles are added to the file and can be selected from the Resource Manager.
Using plant catalogs
