Creating
a foliage symbol definitionTool |
Workspace: Tool set |
Foliage
● Designer: Site Planning ● Landmark: Visualization |
You can create a custom foliage symbol definition from an image file.
To create a foliage symbol definition:
1. Select an existing foliage object for which you want to create a new symbol definition.
2.From the Object Info palette, click Create Symbol. The Create Foliage Symbol dialog box opens.
Click
to show/hide the parameters.
The symbol definition is applied to the selected foliage object.
3.To save the symbol definition for reuse in other files, use the Resource Manager’s Export command to export the symbol definition to a file in the Defaults\Foliage folder in your user folder.
