DesignSeries.pngImporting  an adjacency matrix spreadsheet
Command
Workspace: Path
Import Adjacency Matrix
●       Architect: AEC > Space Planning
●       Landmark and Spotlight: Customize workspace to add command (see Customizing workspaces)
To import an adjacency matrix:
1.      Ensure that the file to be imported is a tab- or comma-delimited file (.txt or .csv).
2.Select the command to open the Import Adjacency Matrix dialog box. Specify the adjacency matrix file import options.
If this is the first time an adjacency matrix, stacking diagram, spaces, or space links are placed in the file, a properties dialog box opens for each type of object. Set the default parameters. The parameters can be edited later from the Object Info palette.
Inserting an adjacency matrix
