Applying sketch styles to hatches|
Command |
Path |
Hatch |
Modify |
Each hatch resource can have its own sketch style, overriding the sketch style applied to the current layer. Apply the “No Sketch” style to hatch resources that should never be sketched.
To specify a hatch sketch style:
1. Select an object that has a hatch resource applied.
2.Select the command.
The Hatches dialog box opens. For more information on hatches, see Defining hatches.
3.Select a hatch and click Edit.
The Edit hatch dialog box opens.
4.The document default displays as the Sketch Style. Select a different style to use in sketch rendering mode, or select No Sketch to never apply a sketch style to the hatch.
Alternatively, from the Resource Manager, right-click on the resource, and select Edit from the context menu.
