Add solids
Command
Path
Shortcut
Add Solids
●       Model
●       Context menu
●       Ctrl+Alt+A (Windows)
●       Cmd+Option+A (Mac)
The Add Solids command joins two or more 3D objects into a single solid object.
To add solids in 3D:
1.      Select two or more 3D objects to combine.
2.Select the command.
A single solid object is created from the objects.
Solid object interactions
Editing 2D object surfaces
