Intersect solids
Command
Path
Shortcut
Intersect Solids
●       Model
●       Context menu
●       Ctrl+Alt+I (Windows)
●       Cmd+Option+I (Mac)
The Intersect Solids command creates a single solid object from the volume created where two or more 3D objects intersect.
To intersect solids:
1.      Select the two or more 3D objects to combine.
2.Select the command.
A single solid object is created from the 3D objects; it is the size and shape of the overlapping volume of the selected objects.
Solid object interactions
Editing 2D object surfaces
