Command |
Path |
Create Helix-Spiral |
Model > 3D Power Pack |
The Create Helix-Spiral command creates a helix-shaped or spiral-shaped 3D object from one or more path objects. The paths can be 2D objects or NURBS curves.
To create a helix or spiral:
1. Select the object to use as the path.
2.Select the command.
The Helix-Spiral Creation dialog box opens; specify the object parameters.
A helix or spiral is created.
A helix or spiral object can be used, without further conversion, as a path object for the Extrude Along Path command.
Ungrouping a helix-spiral object results in a NURBS curve.
