DesignSeries00134.pngInserting grade objects
Mode
Tool
Workspace: Tool set
Insert
Grade
●       Architect and Spotlight: Building Shell
●       Landmark: Site Planning
To insert a grade object:
1.      Click the tool and mode.
2.Click to set the start of the grade. Move the cursor and click again to set the end point.
If connecting the grade object to another grade object, forming a network, the existing grade object is highlighted.
The Grade Settings dialog box opens. Click the Object Properties tab and enter the desired settings.
Grade objects can be edited from the Object Info palette. Commonly-required parameters can be accessed directly from the Object Info palette, or click Settings to change any of the parameters of selected grade objects. Alternatively, edit the settings of a grade object by double-clicking on it, or right-click on a grade object and select Edit from the context menu.
Grade objects can be connected to form a network. Either move the endpoint of one grade object onto another grade object, or create a new grade object with an end point on an existing grade object. The existing grade object is split at the new endpoint, creating a network of overlapping grade objects. The elevation of the shared point is interpolated from the slope of the existing object; if an elevation point is updated, all overlapping grade objects automatically update. Click Update mode from the Tool bar of the Grade tool to force an update of all overlapping grade objects.
When grade objects are connected in a network, they move as one object and all elevations adjust accordingly. Detach a grade from its network, making it an independent grade object, by selecting Detach from Grade Network from the drop-down context menu.
Calculating and displaying grade and elevation
Specifying global grade object preferences
Editing elevation
Analyzing grade
Creating loci from a grade object
Site model section
Inserting stake objects
