Using
saved sets for stair settingsIn the Stair Settings dialog box, the 2D Graphics, Construction, Railings, and Graphic Attributes tabs have the option of saving the tab’s current settings so that they can be quickly applied again. Parameter sets are saved and applied for the active tab only, not for the entire stair. The stair minimum/maximum value settings can also be saved as a set.
To use saved sets:
Open the Stair Settings dialog box and select the desired tab.
The top left part of the dialog box offers options for saved settings.
Click
to show/hide the parameters.
