Bulb flatMode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Bulb Flat
Detailing |
The Bulb Flat tool and Bulb Flat - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To create a bulb flat object:
1. Click the tool and mode.
2.Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
