Shaft break 2Tool |
Tool set |
Shaft Break 2
Detailing |
To insert a shaft break 2 object.
1. Click the tool and mode.
2.Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Click
to show/hide the parameters.
