You can add backgrounds to your drawing to make it more realistic. Backgrounds, such as clouds, a color or color gradient, or an imported image or panorama, are applied on a per-layer basis. A physical sky background can be combined with a heliodon (Vectorworks Design Series required) to create a realistic sky, correct in appearance for the time of day. In addition, a special lit fog effect can add the illusion of shafts of light in fog (point or spot light required).
Click here and here for video tips about this topic (internet access required). |
Renderworks backgrounds are resources that are created and displayed in the Resource Manager and Resource Selector and are saved with the file. Several Renderworks backgrounds are provided in the Vectorworks Libraries. Several Renderworks styles make use of backgrounds.
To create a background:
1. From the Resource Manager, click New Resource, select Renderworks Background, and then click Create. Alternatively, from the Resource Manager, select Renderworks Backgrounds from the list of resource types on the tool bar, and click New Renderworks Background.
The Edit Renderworks Background dialog box opens.
2.Enter the name of the new background and select the type of background to create. Click Options to set specific background parameters.
Click
to show/hide the parameters.
OpenGL render mode only displays One Color, Two Color, and Image backgrounds.
The new background resource is listed in the Resource Manager. It is available in the Edit Design Layers dialog box (see Applying Renderworks backgrounds for information).
To quickly edit a Renderworks background, press Ctrl (Windows) or Option (Mac) and double-click on the resource in the Resource Manager.
Backgrounds and lit fog effects can be used together.
Purge textures and backgrounds that are not used in the drawing file to reduce file size. See Purging items from a file.
