Layer link objects can be cropped in a similar manner to viewports (see Cropping existing sheet layer or design layer viewports), although the area outside of the crop cannot be displayed as it can for a sheet layer or design viewport. When cropped, only a portion of the layer link displays; increase the scale of the layer to create a detailed view. Layer links with workgroup-referenced layers can also be cropped.
To crop a layer link:
1. Select an existing layer link.
2.Unlock the layer link by selecting Modify > Unlock.
3.Click Edit Crop from the Object Info palette to enter the Layer Link Crop mode.
Alternatively, right-click on a layer link and select Edit Crop from the context menu.
A colored border around the drawing window indicates that you are in an editing mode. The Exit Crop command becomes available from the Modify menu, and the Exit Layer Link Crop button displays in the top right corner of the drawing window.
4.Create a 2D object such as a rectangle, circle, or polyline. The 2D object must define an area; a 2D line, for example, cannot be used. Position the 2D object to delimit the new crop display area. The fill of a cropping object is always None; however, the pen style can be set from the Attributes palette while in Edit Crop mode. Set the pen style to None (or the crop object class to invisible) to make the crop object invisible.
Use the Flyover tool to adjust the view (see Flyover).
5.Click Exit Layer Link Crop, or select Modify > Exit Crop to return to the drawing.
The cropped layer link is displayed. In the Object Info palette, the crop status has changed to Yes.
By increasing the scale of the layer with the layer link, and making other layers visible, a floor plan can be displayed (original design layer) along with a detailed view of the floor plan (zoomed in, cropped layer link).
To change, replace, or delete the layer link crop, select the cropped layer link and then select Edit Crop from the Object Info palette to re-enter crop mode. Click Exit Layer Link Crop, or select Modify > Exit Crop to return to the drawing.
The entire layer link is displayed if a viewport of a cropped layer link is created.
