DesignSeries.pngEditing walls
Once a wall has been created, there are multiple ways to edit it:
●       Edit parameters from the Object Info palette.
●       Reshape walls using the Selection tool, the Reshape tool and the Delete Wall Peaks command.
●       Remove wall breaks.
●       Join walls and wall components, and move connected walls.
●       Edit curtain wall grids.
Wall properties
Reshaping walls
Removing wall breaks
Moving connected walls
Joining walls
Joining wall components
Editing curtain wall grids
