DesignSeries00066.pngT wall joins
Mode
Tool
Workspace: Tool set
Shortcut
T Join
Wall Join
●       Architect and Spotlight: Building Shell
●       Landmark: Building Shell and Site Planning
●       Alt+J (Windows)
●       Option+J (Mac)
T Join mode lengthens or shortens the first wall segment selected until it intersects with the second wall segment selected. As only the first wall is altered, this mode does not create corner joins.
To join walls with the T Join mode:
1.      Click the tool and mode.
Alternatively, right-click on the first wall to join and select Join from the context menu.
2.Select the wall segment that must change length to intersect with the other wall.
3.Select the second wall segment to join.
To create a T join to an existing corner, join the wall segment to the perpendicular corner segment. This creates a clean join between the walls.
Joining walls
Joining walls with the Fillet tool
