Worksheet functions
Worksheet functions take an argument, perform an action, and return a value or values. There are two basic types of functions: those that use the values you enter, and those that use information from objects in the drawing. The arguments required by the two function types are different.
●       Number or text arguments: Functions that begin with a lower case letter typically require a number value or a cell address as the argument. For example, the acos function returns the arccosine of the value that is specified in the function argument. The argument you enter can be a mathematical expression (such as 3/5), an address of a cell that contains a number (such as A12), or an actual number. The argument for all trigonometry functions must be in radians.
●       Criteria arguments: Functions that begin with a capital letter must be applied to one or more specific objects in the drawing. In a cell in a database header row, a function is automatically applied to the object listed in each sub-row, so no criteria argument is required.
However, in a spreadsheet cell, you must enter criteria to select the objects the function applies to. For example, the Area function returns the combined area of all 2D objects that meet the criteria. To specify which objects to obtain the area of, either use the Insert > Criteria command on the Worksheet menu, or enter the criteria manually. For details about how to specify criteria such as the object type, class, or visibility, see the developer-oriented documentation here (internet access required):
developer.vectorworks.net/index.php/VS:Search_Criteria#Search_Criteria_Tables
developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#attrCrit
●       Material properties: In Design Series products, material resource data can be reported by property. Worksheets functions appear in the alphabetical list of functions here; to find a list of MaterialProperty names and types to use in creating reports, see the developer-oriented documentation here (internet access required):
https://developer.vectorworks.net/index.php/VS:Working_with_Materials#MaterialProperty_values
Use the Formula syntax rules when entering worksheet functions.
In the following list of worksheet functions, the type of argument the function takes is shown in parentheses.
acos(number)
The arccosine of a number. The arccosine is the angle whose cosine is number. The returned angle is given in radians in the range 0 to pi. Number is the cosine of the angle, and must be from -1 to 1. Related function: cos
Example: =acos(3/5) returns the angle for which the cosine value is 3/5
Angle(criteria)
The angle (measured from horizontal) of the objects that meet the specified criteria, in degrees. Use this function to return the angles of lines and walls (measured from horizontal), the span angles of arcs, and the slope angles of slabs.
Examples:
●       Database header cell: =Angle returns the angle of each object in the database
●       Spreadsheet cell: =Angle((t=arc)&(n='arc-1')) returns the sweep angle of the arc object named “arc-1” in the drawing
Area(criteria)
The total area of 2D objects that meet the specified criteria, based on the Area units in the Units dialog box. Related function: Perim
Examples:
●       Database header cell: =Area returns the area of each object in the database
●       Spreadsheet cell: =Area(t=rect) returns the combined area of all rectangle objects in the drawing
asin(number)
The arcsine of a number. The arcsine is the angle whose sine is number. The returned angle is given in radians in the range -pi/2 to pi/2. To express the arcsine in degrees, use the rad2deg function (or multiply the result by 180/pi). Number is the sine of the angle and must be from -1 to 1. Related function: sin
Example: =asin(A3) returns the angle for which the sine value is given in cell A3
atan(number)
The arctangent of a number. The arctangent is the angle whose tangent is number. The returned angle is given in radians in the range -pi/2 to pi/2. To express the arctangent in degrees, use the rad2deg function (or multiply the result by 180/pi). Number is the tangent of the angle and must be from -1 to 1. Related function: tan
Example: =atan(A3) returns the angle for which the tangent value is given in cell A3
average(number1, number2,...)
The average (mean) of all numbers in the list of arguments. The returned value is the number(s), or quantities, added together and their total then divided by the number of quantities. Related function: sum
Example: =average(A2,A10..A12) returns the average of the numbers contained in cells A2, A10, A11, and A12
BotBound(criteria)
The bottom 2D boundary (minimum y coordinate) of the objects that meet the specified criteria. Related functions: LeftBound, RightBound, TopBound
Examples:
●       Database header cell: =BotBound returns the bottom 2D boundary of each object in the database
●       Spreadsheet cell: =BotBound(t=locus) returns the bottom 2D boundary of the locus that has the lowest bottom 2D boundary value in the drawing
Class(criteria)
The class name of objects that meet the specified criteria.
Examples:
●       Database header cell: =Class returns the class of each object in the database
●       Spreadsheet cell: =Class(sel=true) returns the class name of the selected objects in the drawing
CompAreaByClass(criteria, class)
The area (minus any holes) of one side of the components that meet the specified criteria and are in the specified class. Related functions: CompAreaByName, CompAreaByMat, ComponentArea
Examples:
●       Database header cell: =CompAreaByClass('Class-1') returns the combined area of the components assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompAreaByClass(t=wall,'Class-1') returns the combined area of the components assigned to the class “Class-1” for all walls in the drawing
CompAreaByMat(criteria, material)
The area (minus any holes) of one side of the components that meet the specified criteria and use the specified material. Related functions: CompAreaByClass, CompAreaByName, ComponentArea
Examples:
●       Database header cell: =CompAreaByMat('Mortar MT') returns the combined area of the components that use the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompAreaByMat(t=wall, 'Mortar MT') returns the combined area of the components that use the material “Mortar MT” for all walls in the drawing
CompAreaByName(criteria, name)
The area (minus any holes) of one side of the components that meet the specified criteria and have the specified name. Related functions: CompAreaByClass, CompAreaByMat, ComponentArea
Examples:
●       Database header cell: =CompAreaByName('Brick Veneer') returns the combined area of the components with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompAreaByName(t=wall,'Brick Veneer') returns the combined area of the components with the name “Brick Veneer” for all walls in the drawing
CompClassByMat(criteria, material)
The class of the components that meet the specified criteria and use the specified material. Related functions: CompMatByClass, CompClassByName
Examples:
●       Database header cell: =CompClassByMat('Mortar MT') returns the class of the first component that uses the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompClassByMat(t=wall, 'Mortar MT') returns the class of the first component that uses the material “Mortar MT” for all walls in the drawing
CompClassByName(criteria, name)
The class of the components that meet the specified criteria and have the specified name. Related functions: CompNameByClass, CompClassByMat
Examples:
●       Database header cell: =CompClassByName('Brick Veneer') returns the class of the first component with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompClassByName(t=wall,'Brick Veneer') returns the class of the first component with the name “Brick Veneer” for all walls in the drawing
CompLambdaByClass(criteria, class)
The Lambda value of the components that meet the specified criteria and are in the specified class. Related functions: CompLambdaByName, CompLambdaByMat, ComponentLambda
Examples:
●       Database header cell: =CompLambdaByClass('Class-1') returns the Lambda value of the first component assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompLambdaByClass(t=wall,'Class-1') returns the Lambda value of the first component assigned to the class “Class-1” for all walls in the drawing
CompLambdaByMat(criteria, material)
The Lambda value of the components that meet the specified criteria and use the specified material. Related functions: CompLambdaByClass, CompLambdaByName, ComponentLambda
Examples:
●       Database header cell: =CompLambdaByMat('Mortar MT') returns the Lambda value of the first component that uses the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompLambdaByMat(t=wall,'Mortar MT') returns the Lambda value of the first component that uses the material “Mortar MT” for all walls in the drawing
CompLambdaByName(criteria, name)
The Lambda value of the components that meet the specified criteria and have the specified name. Related functions: CompLambdaByClass, CompLambdaByMat, ComponentLambda
Examples:
●       Database header cell: =CompLambdaByName('Brick Veneer') returns the Lambda value of the first component with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompLambdaByName(t=wall,'Brick Veneer') returns the Lambda value of the first component with the name “Brick Veneer” for all walls in the drawing
CompMatByClass(criteria, class)
The materials used by the components that meet the specified criteria and are in the specified class. Related functions: CompClassByMat, CompNameByClass
Examples:
●       Database header cell: =CompMatByClass('Class-1') returns the materials used by the first component assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompMatByClass(t=wall,'Class-1') returns the material used by the first component assigned to the class “Class-1” for all walls in the drawing
CompMatByName(criteria, name)
The materials used by the components that meet the specified criteria and have the specified name. Related functions: CompNameByMat, CompMatByClass
Examples:
●       Database header cell: =CompMatByName('Siding') returns the materials used by the first component with the name “Siding” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompMatByName(t=wall,'Siding') returns the material used by the first component with the name “Siding” for all walls in the drawing
CompNameByClass(criteria, class)
The name of the components that meet the specified criteria and are in the specified class. Related functions: CompClassByName, CompMatByClass
Examples:
●       Database header cell: =CompNameByClass('Class-1') returns the name of the first component assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompNameByClass(t=wall,'Class-1') returns the name of the first component assigned to the class “Class-1” for all walls in the drawing
CompNameByMat(criteria, material)
The name of the components that meet the specified criteria and use the specified material. Related functions: CompMatByName, CompNameByClass
Examples:
●       Database header cell: =CompNameByMat('Mortar MT') returns the name of the first component that uses the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompNameByMat(t=wall,'Mortar MT') returns the name of the first component that uses the material “Mortar MT” for all walls in the drawing
ComponentArea(criteria, index)
The area (minus any holes) of one side of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related function: CompAreaByClass, CompAreaByMat, CompAreaByName
Examples:
●       Database header cell: =ComponentArea(2) returns the combined area of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentArea(t=wall,1) returns the combined area of the first components for all walls in the drawing
ComponentLambda(criteria, index)
The Lambda value of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompLambdaByClass, CompLambdaByMat, CompLambdaByName
Examples:
●       Database header cell: =ComponentLambda(2) returns the Lambda value of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentLambda(t=wall,1) returns the Lambda value of the first component for all walls in the drawing
ComponentMaterial(criteria, index)
The material used by the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related function: CompMatByClass
Examples:
●       Database header cell: =ComponentMaterial(2) returns the material used by the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentMaterial(t=wall,1) returns the material used by the first component for all walls in the drawing
ComponentName(criteria, index)
The name of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompNameByClass, CompNameByMat
Examples:
●       Database header cell: =ComponentName(2) returns the name of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentName(t=wall,1) returns the name of the first component for all walls in the drawing
ComponentRValue(criteria, index)
The R-value of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompRValueByClass, CompRValueByMat, CompRValueByName
Examples:
●       Database header cell: =ComponentRValue(2) returns the combined R-values of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentRValue(t=wall,1) returns the combined R-values of the first components for all walls in the drawing
ComponentThickness(criteria, index)
The thickness of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompThicknessByClass, CompThicknessByMat, CompThicknessByName
Examples:
●       Database header cell: =ComponentThickness(2) returns the combined thickness of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentThickness(t=wall,1) returns the combined thickness of the first components for all walls in the drawing
ComponentUValue(criteria, index)
The U-value of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompUValueByClass, CompUValueByMat,CompUValueByName
Examples:
●       Database header cell: =ComponentUValue(2) returns the combined U-values of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentUValue(t=wall,1) returns the combined U-values of the first components for all walls in the drawing
ComponentVolume(criteria, index)
The volume (minus any holes) of the components that meet the specified criteria and have the specified index. Index is the 1-based index identifying the component. Related functions: CompVolumeByClass, CompVolumeByMat, CompVolumeByName
Examples:
●       Database header cell: =ComponentVolume(2) returns the combined volume of the second component for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =ComponentVolume(t=wall,1) returns the combined volume of the first components for all walls in the drawing
CompRValueByClass(criteria, class)
The R-value of the components that meet the specified criteria and are in the specified class. Related functions: CompRValueByMat, CompRValueByName, ComponentRValue
Examples:
●       Database header cell: =CompRValueByClass('Class-1') returns the combined R-values of the components assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompRValueByClass(t=wall,'Class-1') returns the combined R-values of the components assigned to the class “Class-1” for all walls in the drawing
CompRValueByMat(criteria, material)
The R-value of the components that meet the specified criteria and use the specified material. Related functions: CompRValueByClass, CompRValueByName,ComponentRValue
Examples:
●       Database header cell: =CompRValueByMat('Mortar MT') returns the combined R-values of the components that use the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompRValueByMat(t=wall,'Mortar MT') returns the combined R-values of the components that use the material “Mortar MT” for all walls in the drawing
CompRValueByName(criteria, name)
The R-value of the components that meet the specified criteria and have the specified name. Related functions: CompRValueByClass, CompRValueByMat, ComponentRValue
Examples:
●       Database header cell: =CompRValueByName('Brick Veneer') returns the combined R-values of the components with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompRValueByName(t=wall,'Brick Veneer') returns the combined R-values of the components with the name “Brick Veneer” for all walls in the drawing
CompThicknessByClass(criteria, class)
The thickness of the components that meet the specified criteria and are in the specified class. Related functions: CompThicknessByName, CompThicknessByMat, ComponentThickness
Examples:
●       Database header cell: =CompThicknessByClass('Class-1') returns the combined thickness of the components assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompThicknessByClass(t=wall,'Class-1') returns the combined thickness of the components assigned to the class “Class-1” for all walls in the drawing
CompThicknessByMat(criteria, material)
The thickness of the components that meet the specified criteria and use the specified material. Related functions: CompThicknessByClass, CompThicknessByName, ComponentThickness
Examples:
●       Database header cell: =CompThicknessByMat('Mortar MT') returns the combined thickness of the components that use the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompThicknessByMat(t=wall,'Mortar MT') returns the combined thickness of the components that use the material “Mortar MT” for all walls in the drawing
CompThicknessByName(criteria, name)
The thickness of the components that meet the specified criteria and have the specified name. Related functions: CompThicknessByClass, CompThicknessByMat, ComponentThickness
Examples:
●       Database header cell: =CompThicknessByName('Brick Veneer') returns the combined thickness of the components with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompThicknessByName(t=wall,'Brick Veneer') returns the combined thickness of the components with the name “Brick Veneer” for all walls in the drawing
CompUValueByClass(criteria, class)
The U-value of the components that meet the specified criteria and are in the specified class. Related functions: CompUValueByName, CompUValueByMat, ComponentUValue
Examples:
●       Database header cell: =CompUValueByClass('Class-1') returns the combined U-values of the components assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompUValueByClass(t=wall,'Class-1') returns the combined U-values of the components assigned to the class “Class-1” for all walls in the drawing
CompUValueByMat(criteria, material)
The U-value of the components that meet the specified criteria and use the specified material. Related functions: CompUValueByClass, CompUValueByName, ComponentUValue
Examples:
●       Database header cell: =CompUValueByMat('Mortar MT') returns the combined U-values of the components that use the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompUValueByMat(t=wall,'Mortar MT') returns the combined U-values of the components that use the material “Mortar MT” for all walls in the drawing
CompUValueByName(criteria, name)
The U-value of the components that meet the specified criteria and have the specified name. Related functions: CompUValueByClass, CompUValueByMat, ComponentUValue
Examples:
●       Database header cell: =CompUValueByName('Brick Veneer') returns the combined U-values of the components with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompUValueByName(t=wall,'Brick Veneer') returns the combined U-values of the components with the name “Brick Veneer” for all walls in the drawing
CompVolumeByClass(criteria, class)
The volume of the components that meet the specified criteria and are in the specified class. Related functions: CompVolumeByName, CompVolumeByMat, ComponentVolume
Examples:
●       Database header cell: =CompVolumeByClass('Class-1') returns the combined volume of the components assigned to the class “Class-1” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompVolumeByClass(t=wall,'Class-1') returns the combined volume of the components assigned to the class “Class-1” for all walls in the drawing
CompVolumeByMat(criteria, material)
The volume of the components that meet the specified criteria and have the specified name. Related functions: CompVolumeByClass, CompVolumeByName, ComponentVolume
Examples:
●       Database header cell: =CompVolumeByMat('Mortar MT') returns the combined volume of the components that use the material “Mortar MT” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompVolumeByMat(t=wall,'Mortar MT') returns the combined volume of the components that use the material “Mortar MT” for all walls in the drawing
CompVolumeByName(criteria, name)
The volume of the components that meet the specified criteria and have the specified name. Related functions: CompVolumeByClass, CompVolumeByMat, ComponentVolume
Examples:
●       Database header cell: =CompVolumeByName('Brick Veneer') returns the combined volume of the components with the name “Brick Veneer” for each wall, round wall, roof, roof face, and slab object in the database
●       Spreadsheet cell: =CompVolumeByName(t=wall,'Brick Veneer') returns the combined volume of the components with the name “Brick Veneer” for all walls in the drawing
concat(text1, text2, text3)
Joins several text strings into one text string.
Example: =concat(B3,', ',B4) returns the contents of cells B3 and B4 as a single string, separated by a comma and a space
cos(number)
The cosine of a given angle. Number is the angle in radians for which the cosine is calculated. Related function: acos
Example: =cos(deg2rad(23)) converts a 23-degree angle to its radian equivalent, and returns the cosine of the angle
Count(criteria)
The number of objects that meet the specified criteria.
Examples:
●       Database header cell: =Count returns the total number of objects for each row in the database
●       Spreadsheet cell: =Count(s='simple sofa') returns the total number of symbol objects named “simple sofa” in the drawing
When used with the COUNT function, the SEL (selection status) criterion counts objects that are actually non-selectable, such as the individual items within a group. The VSEL (visible selection status) criterion counts only the visibly selected items, which is the same counting method used for the Object Info palette. For example, if you select and count a group that has 11 items in it, the SEL criterion returns a value of 12 (the group, plus the 11 items). The VSEL criterion returns a value of 1 (the group only).
CurtWallFrameLength(criteria, class)
The combined length of the curtain wall frames that meet the specified criteria and are in the specified class. To find all frames in a curtain wall, use an empty class name. Related functions: CurtWallPnlAreaNet, CurtWallPnlAreaGross
Examples:
●       Database header cell: =CurtWallFrameLength('') returns the combined length of the curtain wall frames for each curtain wall in the database
●       Spreadsheet cell: =CurtWallFrameLength(t=wall, '') returns the combined length of the curtain wall frames for all curtain walls in the drawing
CurtWallPnlAreaGross(criteria, class)
The combined gross area of the curtain wall panels in the walls that meet the specified criteria and are in the specified class. The gross area includes portions of the panel covered by frames. To find all panels in a curtain wall, use an empty class name. Related functions: CurtWallFrameLength, CurtWallPnlAreaNet
Examples:
●       Database header cell: =CurtWallPnlAreaGross('') returns the combined gross area of the curtain wall panels for each curtain wall in the database
●       Spreadsheet cell: =CurtWallPnlAreaGross(t=wall, '') returns the combined gross area of the curtain wall panels for all curtain walls in the drawing
CurtWallPnlAreaNet(criteria, class)
The net area of the curtain wall panels in the walls that meet the specified criteria and are in the specified class. The net area includes only the visible area bounded by frames. To find all panels in a curtain wall, use an empty class name. Related functions: CurtWallFrameLength, CurtWallPnlAreaGross
Examples:
●       Database header cell: =CurtWallPnlAreaNet ('Class-1') returns the combined net area of the curtain wall panels assigned to the class “Class-1” for each curtain wall in the database
●       Spreadsheet cell: =CurtWallPnlAreaNet(t=wall, 'Class-1') returns the combined net area of the curtain wall panels assigned to the class “Class-1” for all curtain walls in the drawing
Database(criteria)
Use this function to create database rows based on the specified criteria. This function defines the formula for the entire database. It is automatically generated when using the Database or Create Report commands. To manually input the database formula, use the Edit Database Formula command.
Related function: DatabasebyScript
Example: =DATABASE((L='Floor-1')) creates a worksheet database of all objects on layer “Floor-1.”
DatabasebyScript(scriptName, param1, param2,...)
Use this function to create database rows based on the specified script. This function is similar to Database, but it uses a script instead of criteria to determine the list of objects for the database. The order of objects in the database can be defined in the script.
The script can be a VectorScript or Python script. Optional parameters for the script can be specified after the script name. An optional parameter before the script name specifies the script’s folder path within the Vectorworks installation. For a list of folder path values, see the developer-oriented documentation here (internet access required):
developer.vectorworks.net/index.php/VS:GetFolderPath
See Running scripts from worksheets for details.
To input the DatabasebyScript formula, use the Edit Database Formula command.
Related functions: Database, RunScript
Example: =DataBaseByScript('MyScript.py', 2, 1) creates a worksheet database by executing the script named “My Script.py,” passing the parameters “2” and “1” to the script.
DataTagField(criteria, label)
The value of a dynamic text field for all data tag objects that meet the specified criteria and have a dynamic text field with the specified label in the layout.
Examples:
●       Database header cell: =DataTagField('Color'), where “Color” is the label of a user-entered text field in a data tag, returns the value for the “Color” field (for example, “Red”) for each data tag in the database.
●       Spreadsheet cell: =DataTagField(sel=true, 'Color'), where “Color” is the label of a user-entered text field in a data tag, returns the value for the “Color” field (for example, “Red”) for the selected data tag in the drawing.
deg2rad(number)
Converts a number from degrees to radians. Number is the value in degrees to be converted to radians.
Example: =deg2rad(47) converts the 47-degree angle measurement to its radian equivalent
exp(number)
e raised to the power of number. The constant e equals 2.71828182845904, the base of the natural logarithm. Number is the exponent applied to the base e.
Example: =exp(2) returns the numeric value of e raised to the power of 2
FormatField(criteria, format_name, format_field)
The value of a record format field for all objects that meet the specified criteria with the specified record format.
Examples:
●       Database header cell: =FormatField(‘Door’, ‘Width’), where “Door” is the name of a record format, returns the value for the “Width” field for each object in the database.
●       Spreadsheet cell: =FormatField(sel=true, 'Door', ‘Width’), where “Door” is the name of a record format, returns the value for the “Width” field for the selected objects in the drawing.
GetCOBieProperty(criteria)
(Vectorworks Design Series required) The value of a COBie property for an object. The criteria is a string with two elements separated by a period. The first element is the name of the COBie worksheet and the second element is the name of the column in that worksheet.
Example: =GETCOBIEPROPERTY ('space.floorname') returns the FloorName value for objects whose COBie property is Space
GetCOBieSource(criteria)
(Vectorworks Design Series required) The data source of the selected worksheet and column of an object. The criteria is a string with two elements separated by a period. The first element is the name of the COBie worksheet and the second element is the name of the column in that worksheet.
Example: =GETCOBIESOURCE ('space.floorname') returns the FloorName data source for objects whose COBie property is Space
GetIfcProperty(criteria)
(Vectorworks Design Series required) The value of a specific IFC property associated with an IFC object. The criteria is a string with two elements separated by a period. The first element is either an IFC entity or PSet name, and the second element is the name of the IFC property.
Example: =GETIFCPROPERTY ('ifcfurnishingelement.name') returns the Name value for IFC objects whose IFC entity is IfcFurnishingElement
GetSpaceNameForObj(criteria)
(Vectorworks Architect required) The name of the space that surrounds the object that meets the specified criteria. Related function: GetSpaceNumForObj
Examples:
●       Database header cell: =GetSpaceNameForObj returns the space name for each object in the database
●       Spreadsheet cell: =GetSpaceNameForObj(n='chair-1') returns the space name for the object named “chair-1”
GetSpaceNumForObj(criteria)
(Vectorworks Architect required) The number of the space that surrounds the object that meets the specified criteria. Related function: GetSpaceNameForObj
Examples:
●       Database header cell: =GetSpaceNumForObj returns the space number for each object in the database
●       Spreadsheet cell: =GetSpaceNumForObj(n='chair-1') returns the space number for the object named “chair-1”
GradientFill(criteria)
The gradient fill of objects that meet the specified criteria.
Examples:
●       Database header cell: =GradientFill returns the gradient fill for each object in the database
●       Spreadsheet cell: =GradientFill(sel=true) returns the gradient fill of the selected objects in the drawing
HatchFill(criteria)
The hatch fill of objects that meet the specified criteria.
Examples:
●       Database header cell: =HatchFill returns the hatch fill for each object in the database
●       Spreadsheet cell: =HatchFill(sel=true) returns the hatch fill of the selected objects in the drawing
Height(criteria)
The combined delta y (height) of objects that meet the specified criteria. Related function: Width
Examples:
●       Database header cell: =Height returns the height (delta y) for each object in the database
●       Spreadsheet cell: =Height(sel=true) returns the combined height (delta y) value of the selected objects in the drawing
if ((logical_test), value_if_true, value_if_false)
Use value_if_true if logical_test is true, value_if_false if logical_test is false.
Use this function to conduct conditional tests on values and formulas and to branch based on the results of that test. The outcome of the test determines the value returned by the If function. The logical_test can be any value or expression that can be evaluated to true or false. Up to seven If statements can be nested as value_if_true, value_if_false arguments. Boolean statements within an if statement must be in parentheses. Text within an if statement should be enclosed within quotation marks.
Examples:
●       =if(('Existing Tree'.'Condition'='Not Set'), '-', 'Existing Tree'.'Condition') If no condition value was set for the existing tree object, the value in this cell is a dash; otherwise, the value in this cell is the condition value that was set for the tree object.
●       =if(('Existing Tree'.'Condition'='Not Set'); '-'; 'Existing Tree'.'Condition')
Image(criteria)
The image associated with the object that meets the specified criteria. In the cell format, specify whether to show a thumbnail of the object, or the 2D attributes applied to the object.
Examples:
●       Database header cell: =Image returns the image for each object in the database
●       Spreadsheet cell: =Image(s='cabinet') returns the image of the symbol named “Cabinet”
ImageByDataVis(visualization name)
(Design Series required) Applies the named data visualization to images associated with an object.
Examples:
●       Database header cell: =Imagebydatavis('truss by type') applies the “truss by type” data visualization to each image in the database rows
●       Spreadsheet cell: =Imagebydatavis('offices') applies the data visualization named “offices” to the image in the cell
ImageByViewport(viewport name)
(Design Series required) Applies one or more data visualizations that have been assigned to the named viewport, to images associated with an object. If no data visualization is currently applied to the viewport, the image displays normally.
Examples:
●       Database header cell: =Imagebyviewport('Plan A') applies the data visualizations from the viewport named “Plan A” to each image in the database
●       Spreadsheet cell: =Imagebyviewport('Space Allocation') applies the data visualization from the viewport named “Space Allocation” to the image in the cell
ImageFill(criteria)
The image fill of objects that meet the specified criteria.
Examples:
●       Database header cell: =ImageFill returns the image fill for each object in the database
●       Spreadsheet cell: =ImageFill(sel=true) returns the image fill of the selected objects in the drawing
int(number)
Rounds a number down to the nearest integer. Number is the real number to be changed to an integer. Related functions: round, rounddown
Example: =int(3.8) returns the value 3
IsFlipped(criteria)
The flipped state of the objects that meet the specified criteria.
Examples:
●       Database header cell: =IsFlipped returns the flip state for each object in the database
●       Spreadsheet cell: =IsFlipped(PON=window) returns the total number of window objects in the drawing that are flipped
Layer(criteria)
The layer name of objects that meet the specified criteria.
Examples:
●       Database header cell: =Layer returns the layer of each object in the database
●       Spreadsheet cell: =Layer(sel=true) returns the layer name of the selected objects in the drawing
LeftBound(criteria)
The left side 2D boundary (minimum x coordinate) of the objects that meet the specified criteria. Related functions: BotBound, TopBound, RightBound
Examples:
●       Database header cell: =LeftBound returns the left 2D boundary for each object in the database
●       Spreadsheet cell: =LeftBound(t=locus) returns the left 2D boundary of the leftmost locus in the drawing
Length(criteria)
The length of lines, walls, or path-based objects that meet the specified criteria.
Examples:
●       Database header cell: =Length returns the length for each object in the database
●       Spreadsheet cell: =Length(t=line) returns the total length of all line objects in the drawing
LineType(criteria)
The line type of objects that meet the specified criteria.
Examples:
●       Database header cell: =LineType returns the line type for each object in the database
●       Spreadsheet cell: =LineType(sel=true) returns the line type of the selected objects in the drawing
ln(number)
The natural logarithm (base e). Number is the positive real number for which the logarithm is calculated. Related function: exp
Example: =ln(12) returns the natural logarithm of 12
log(number)
The base 10 logarithm. Number is the positive real number for which the logarithm is calculated. Related function: ln
Example: =log(100) returns the base 10 logarithm of 100
MaterialCount(criteria)
The number of materials of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialCount returns the total number of materials in objects for each row in the database
●       Spreadsheet cell: =MaterialCount(t=wall) returns the total number of materials in walls in the drawing
MaterialIsSimple(criteria)
The simple materials of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialIsSimple returns the simple materials in objects for each row in the database
●       Spreadsheet cell: =MaterialIsSimple(t=wall) returns the simple materials in walls in the drawing
MaterialName(criteria)
The names of materials of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialName returns the names of materials in objects for each row in the database
●       Spreadsheet cell: =MaterialName(t=wall) returns the names of materials in walls in the drawing
MaterialPartName(criteria, materialName)
The names of the material-bearing geometry (parts) of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialPartName('Metal Steel MT') returns the name of the first part that uses the material “Metal Steel MT” for each row in the database
●       Spreadsheet cell: =MaterialPartName(t=stair, 'Metal Steel MT') returns the name of the first part that uses the material “Metal Steel MT” for stairs in the drawing
MaterialPercent(criteria, materialName)
The percentage of the specified material of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialPercent('Mortar MT') returns the percentage of the material “Mortar MT” in all objects for each row in the database
●       Spreadsheet cell: =MaterialPercent(t=wall,'Mortar MT') returns the percentage of the material “Mortar MT” for all walls in the drawing
MaterialProperty(materialName, propertyName)
The named property for the object’s named material.
Example:
●       Database header cell: =MaterialProperty('Mortar MT','MaterialFinish') returns the material finish property for the material “Mortar MT”
MaterialSurfaceArea(criteria, materialName)
The surface area of the objects that use the specified material and that meet the specified criteria.
Examples:
●       Database header cell: =MaterialSurfaceArea('Mortar MT') returns the surface area for objects that use the material named “Mortar MT” for all objects for each row in the database
●       Spreadsheet cell: =MaterialSurfaceArea(t=wall,'Mortar MT') returns the surface area for objects that use the material named “Mortar MT” for all walls in the drawing
MaterialTexture(criteria)
The texture of materials of objects that meet the specified criteria.
Examples:
●       Database header cell: =MaterialTexture returns the textures of materials in objects for each row in the database
●       Spreadsheet cell: =MaterialTexture(t=wall) returns the textures of materials in walls in the drawing
MaterialVolume(criteria, materialName)
The volume of the objects that use the specified material and that meet the specified criteria.
Examples:
●       Database header cell: =MaterialVolume('Mortar MT') returns the volume for objects that use the material named “Mortar MT” for all objects for each row in the database
●       Spreadsheet cell: =MaterialVolume(t=wall,'Mortar MT') returns the volume for objects that use the material named “Mortar MT” for all walls in the drawing
max(number1, number2,...)
The largest number in the list of arguments. Number is 1–14 numbers for which the maximum value is to be found. Related function: min
Example: =max(C5,C7,C9) returns the largest of the numbers that are in cells C5, C7, and C9
min(number1, number2,...)
The smallest number in the list of arguments. Number is 1–14 numbers for which the minimum value is to be found. Related function: max
Example: =min(C5,C7,C9) returns the smallest of the numbers that are in cells C5, C7, and C9
Name(criteria)
The name of objects that meet the specified criteria.
Examples:
●       Database header cell: =Name returns the name for each object in the database
●       Spreadsheet cell: =Name(sel=true) returns the name of the selected objects in the drawing
ObjectTexture(criteria)
The texture of objects that meet the specified criteria.
Examples:
●       Database header cell: =ObjectTexture returns the texture of each object in the database
●       Spreadsheet cell: =ObjectTexture(sel=true) returns the texture of the selected objects in the drawing
ObjectType(criteria)
The numeric object type ID of objects that meet the specified criteria. For a list of object type IDs, see the developer-oriented documentation here (internet access required):
developer.vectorworks.net/index.php/VS:Function_Reference_Appendix#objects
Examples:
●       Database header cell: =ObjectType returns the object type value for each object in the database
●       Spreadsheet cell: =ObjectType(sel=true) returns the object type value of the selected object; for example, the object type value for a light is 81
ObjectTypeName(criteria)
The type name of objects that meet the specified criteria.
Examples:
●       Database header cell: =ObjectTypeName returns the type name for each object in the database
●       Spreadsheet cell: =ObjectTypeName(sel=true) returns the type name of the selected objects in the drawing
ObjIncludeInEnergos(criteria)
(Vectorworks Architect required) The Energos status (1 if it is included in calculations, 0 if it is not) of the objects that meet the specified criteria.
Examples:
●       Database header cell: =ObjIncludeInEnergos returns the Energos status for each wall, round wall, roof, roof face, slab, door, and window object in the database
●       Spreadsheet cell: =ObjIncludeInEnergos(t=wall) returns the Energos status for all walls in the drawing
ObjRValue(criteria)
(Vectorworks Architect required) The R-value of objects that meet the specified criteria. Related function: ObjUValue
Examples:
●       Database header cell: =ObjectRValue returns the R-value for each wall, round wall, roof, roof face, slab, door, and window object in the database
●       Spreadsheet cell: =ObjectRValue(n='wall-1') returns the R-value for the wall named “wall-1”
ObjUValue(criteria)
(Vectorworks Architect required) The U-value of objects that meet the specified criteria. Related function: ObjRValue
Examples:
●       Database header cell: =ObjectUValue returns the U-value for each wall, round wall, roof, roof face, slab, door, and window object in the database
●       Spreadsheet cell: =ObjectUValue(n='wall-1') returns the U-value for the wall named “wall-1”
Perim(criteria)
The combined perimeter of objects that meet the specified criteria.
Examples:
●       Database header cell: =Perim returns the perimeter for each object in the database
●       Spreadsheet cell: =Perim(sel=true) returns the total perimeter of all selected objects
PlantImage(criteria, number)
(Vectorworks Landmark required) The specific plant image from the plant style’s plant data pane. Indicate 1, 2, 3, or 4 to set the image from the Image Plant Form, Image Detail, Image Misc, or Custom Image, respectively. In the cell format, specify the plant by criteria (by selecting the plant with criteria such as, Field value = Plant ID = xx).
Examples:
●       Database header cell: =PlantImage(2) displays the image specified for Image Detail in the Plant Data pane of the plant symbol definition
●       Spreadsheet cell: =PlantImage((‘Plant’.’plant ID’=’TaxfR’), 4) displays the image specified for Custom Image in the Plant Data pane of the plant symbol definition with a plant ID of TaxfR
PluginStyleName(criteria)
The name of the plug-in style for all objects that meet the specified criteria.
Examples:
●       Database header cell: =PluginStyleName returns the plug-in style name for each object in the database.
●       Spreadsheet cell: =PluginStyleName(sel=true) returns the plug-in style name for all selected objects in the drawing.
rad2deg(number)
Converts a number from radians to degrees. Number is the value in radians to be converted to degrees.
Example: =rad2deg(0.5235987) converts the radian angle measurement to its degree equivalent
RightBound(criteria)
The right side 2D boundary (maximum x coordinate) of the objects that meet the specified criteria. Related functions: BotBound, TopBound, LeftBound
Examples:
●       Database header cell: =RightBound returns the right 2D boundary for each object in the database
●       Spreadsheet cell: =RightBound(t=rect) returns the right 2D boundary of the rightmost rectangle in the drawing
RoofArea_Heated(criteria)
The heated area of the roof (minus the eave overhang) along the slope, combined for all objects that meet the specified criteria. Related function: RoofArea_HeatedProj
Examples:
●       Database header cell: =RoofArea_Heated returns the heated area for each roof and roof face object in the database
●       Spreadsheet cell: =RoofArea_Heated (st=roofface) returns the combined heated area of all roof face objects in the drawing
RoofArea_HeatedProj(criteria)
The heated area of the roof (minus the eave overhang) projected to the layer plane, combined for all objects that meet the specified criteria. Related function: RoofArea_Heated
Examples:
●       Database header cell: =RoofArea_HeatedProj returns the heated area for each roof and roof face object in the database, as projected to the layer plane
●       Spreadsheet cell: =RoofArea_HeatedProj (t=roof) returns the combined heated area of all roof objects in the drawing, as projected to the layer plane
RoofArea_Total(criteria)
The total area of the roof along the slope. Related function: RoofArea_TotalProj
Examples:
●       Database header cell: =RoofArea_Total returns the total area for each roof and roof face object in the database
●       Spreadsheet cell: =RoofArea_Total(st=roofface) returns the combined total area of all roof face objects in the drawing
RoofArea_TotalProj(criteria)
The total area of the roof, projected to the layer plane. Related function: RoofArea_Total
Examples:
●       Database header cell: =RoofArea_TotalProj returns the total area for each roof and roof face object in the database, as projected to the layer plane
●       Spreadsheet cell: =RoofArea_Totalproj(t=roof) returns the combined total area of all roof objects in the drawing, as projected to the layer plane
RoofStyleName(criteria)
(Vectorworks Design Series required) The name of the roof style.
Examples:
●       Database header cell: =RoofStyleName returns the roof style name for each roof object in the database
●       Spreadsheet cell: =RoofStyleName(n='roof-1') returns the roof style name for the object named “roof-1”
round(number)
Rounds the specified number to the nearest whole number. Related function: int
Example: =round(2.345) returns 2
rounddown(number, digits)
Rounds the specified number down to the specified number of decimal digits. Related functions: round, roundup
Example: =rounddown(2.345, 2) returns 2.34
roundup(number, digits)
Rounds the specified number up to the specified number of decimal digits. Related functions: round, rounddown
Example: =roundup(2.345, 2) returns 2.35
RunScript(scriptName, param1, param2,...)
Runs the specified VectorScript or Python script, passing the parameters that follow the script name to the script. An optional parameter before the script name specifies the script’s folder path within the Vectorworks installation. For a list of folder path values, see the developer-oriented documentation here (internet access required):
Related function: DataBaseByScript
Examples:
●       Database header cell: =RunScript('My Script') executes the VectorScript script named “My Script” and returns a value for each object in the database
●       Spreadsheet cell: =RunScript(2, 'ScriptFile.py', 2, 1) executes the Python script “ScriptFile.py” in the Vectorworks Plug-Ins folder, passing the parameters “2” and “1,” and returns a value
sin(number)
The sine of a given angle. Number is the angle in radians for which the sine is calculated. Related function: asin
Example: =sin(deg2rad(32)) converts a 32-degree angle to its radian equivalent, and returns the sine of the angle
SketchStyle(criteria)
The sketch style of objects that meet the specified criteria.
Examples:
●       Database header cell: =SketchStyle returns the sketch style for each object in the database
●       Spreadsheet cell: =SketchStyle(sel=true) returns the sketch style of the selected objects in the drawing
SlabStyleName(criteria)
(Vectorworks Design Series required) The name of the slab style.
Example:
●       Database header cell: =SlabStyleName returns the name of the slab style for each slab object in the database
●       Spreadsheet cell: =SlabStyleName(n='slab-1') returns the name of the slab style for the object named “slab-1”
SlabThickness(criteria)
(Vectorworks Design Series required) The combined thickness of slab objects (floors and roof faces) that meet the specified criteria.
Examples:
●       Database header cell: =SlabThickness returns the thickness for each object in the database
●       Spreadsheet cell: =SlabThickness(PON=slab) returns the combined thickness of all slab objects in the drawing
sqrt(number)
A positive square root. Number is the number for which the square root is calculated.
Example: =sqrt(D27) returns the square root of the number in cell D27
Story(criteria)
The story name of objects that meet the specified criteria.
Examples:
●       Database header cell: =Story returns the story name for each object in the database
●       Spreadsheet cell: =Story(sel=true) returns the story name of the selected objects in the drawing
Substring(text/function, delimiter, index)
Splits a single string into an array of strings using a delimiter, and outputs each string at the specified index.
Example: =SUBSTRING('kitchen;bedroom;bathroom;basement', ';', 2) returns “bedroom,” which is the second substring in the specified string
sum(number1, number2,...)
The sum of all numbers in the list of arguments. Number is 1–14 numbers for which the sum is calculated. Related function: Average
Example: =sum(A2,A10..A12) returns the sum of the numbers contained in cells A2, A10, A11, and A12
SurfaceArea(criteria)
The total surface area of all objects that meet the criteria, based on the Area units in the Units dialog box.
Examples:
●       Database header cell: =SurfaceArea returns the surface area for each object in the database
●       Spreadsheet cell: =SurfaceArea(st=sphere) returns the total surface area of all sphere objects in the drawing
SymbolName(criteria)
The symbol name of the symbol instances that meet the specified criteria.
Examples:
●       Database header cell: =SymbolName returns the name for each symbol instance in the database
●       Spreadsheet cell: =SymbolName(sel=true) returns the symbol name of the selected symbol instances in the drawing
tan(number)
The tangent of the given angle. Number is the angle in radians for which the tangent is calculated. Related function: atan
Example: =tan(deg2rad(32)) converts a 32-degree angle to its radian equivalent, and returns the tangent of the angle
TileFill(criteria)
The tile fill of objects that meet the specified criteria.
Examples:
●       Database header cell: =TileFill returns the tile fill for each object in the database
●       Spreadsheet cell: =TileFill(sel=true) returns the tile fill of the selected objects in the drawing
TopBound(criteria)
The top 2D boundary (maximum y coordinate) of the objects that meet the specified criteria. Related functions: BotBound, LeftBound, RightBound
Examples:
●       Database header cell: =TopBound returns the top 2D boundary for each object in the database
●       Spreadsheet cell: =TopBound(sel=true) returns the top 2D boundary of the topmost selected object
value(text)
Converts a text string that represents a number to a number.
Example: =value('2e3') returns the numeric value of 2 times 10 raised to the power of 3
Volume(criteria)
The total volume of all objects that meet the criteria, based on the Volume units in the Units dialog box.
Examples:
●       Database header cell: =Volume returns the volume for each object in the database
●       Spreadsheet cell: =Volume(t=xtrd) returns the total volume of all extrude objects in the drawing
WallArea_Gross(criteria)
The average of the 2D gross surface area of the interior and exterior face of one wall (ignoring holes in the wall), for walls that meet the specified criteria. Related functions: WallArea_Net, ComponentArea, CompAreaByClass, CompAreaByName
Examples:
●       Database header cell: =WallArea_Gross returns the average of the gross area of the interior and exterior face of the wall, for each wall in the database; the gross area ignores holes in the wall
●       Spreadsheet cell: =WallArea_Gross(t=wall) returns the average of the gross area of the interior and exterior face of the wall, combined for all walls in the drawing; the gross area ignores holes in the wall
WallArea_Net(criteria)
The average of the 2D net surface area of the interior and exterior face of one wall (adjusted for holes in the wall), for walls that meet the specified criteria. Related functions: WallArea_Gross, ComponentArea, CompAreaByClass, CompAreaByName
Examples:
●       Database header cell: =WallArea_Net returns the average of the net area of the interior and exterior face of the wall, for each wall in the database; the net area is adjusted for holes in the wall
●       Spreadsheet cell: =WallArea_Net(t=wall) returns the average of the net area of the interior and exterior face of the wall, combined for all walls in the drawing; the net area is adjusted for holes in the wall
WallAverageHeight(criteria)
The average height of a wall, including wall peaks and different starting and ending heights, for walls that meet the specified criteria.
Examples:
●       Database header cell: =WallAverageHeight returns the average height for each wall object in the database
●       Spreadsheet cell: =WallAverageHeight((t=wall)&(sel=true)) returns the average height of all walls that are selected in the drawing
WallOverallHeight(criteria)
The overall height of a wall, ignoring wall peaks and individual component offsets, for walls that meet the specified criteria.
Examples:
●       Database header cell: =WallOverallHeight returns the average overall height for each wall object in the database
●       Spreadsheet cell: =WallOverallHeight((t=wall)&(sel=true)) returns the average overall height of all walls that are selected in the drawing
WallStyleName(criteria)
(Vectorworks Design Series required) The name of the wall style.
Example:
●       Database header cell: =WallStyleName returns the name of the wall style for each wall object in the database
●       Spreadsheet cell: =WallStyleName(n='wall-1') returns the name of the wall style for the object named “wall-1”
WallThickness(criteria)
The combined thickness of wall objects that meet the specified criteria.
Examples:
●       Database header cell: =WallThickness returns the thickness for each wall object in the database
●       Spreadsheet cell: =WallThickness(t=wall) returns the combined thickness of all walls in the drawing
Width(criteria)
The combined delta x (width) of objects that meet the specified criteria. Related function: Height
Examples:
●       Database header cell: =Width returns the width (delta x) for each object in the database
●       Spreadsheet cell: =Width(sel=true) returns the combined width (delta x value) of the selected object
XCenter(criteria)
The x coordinate of the center point of an object that meets the specified criteria. Related functions: YCenter, ZCenter, XCoordinate
Examples:
●       Database header cell: =XCenter returns the x coordinate value of the center of the 2D boundary for each object in the database
●       Spreadsheet cell: =XCenter(sel=true) returns the x coordinate value of the center of the 2D boundary of the selected object
XCoordinate(criteria)
The x coordinate of the insertion point for symbols, point plug-in objects, and loci. The returned value is relative to the user origin. Related functions: YCoordinate, ZCoordinate, XCenter
Example:
●       Database header cell: =XCoordinate returns the x coordinate value for each object in the database
YCenter(criteria)
The y coordinate of the center point of an object that meets the specified criteria. Related functions: XCenter, ZCenter, YCoordinate
Examples:
●       Database header cell: =YCenter returns the y coordinate value of the center of the 2D boundary for each object in the database
●       Spreadsheet cell: =YCenter(sel=true) returns the y coordinate value of the center of the 2D boundary of the selected object
YCoordinate(criteria)
The y coordinate of the insertion point for symbols, point plug-in objects, and loci. The returned value is relative to the user origin. Related functions: XCoordinate, ZCoordinate, YCenter
Example:
●       Database header cell: =YCoordinate returns the y coordinate value for each object in the database
ZCenter(criteria)
The z coordinate of the center point of an object that meets the specified criteria. Related functions: XCenter, YCenter, ZCoordinate
Examples:
●       Database header cell: =ZCenter returns the z coordinate value of the center of the 2D boundary for each object in the database
●       Spreadsheet cell: =ZCenter(sel=true) returns the z coordinate value of the center of the 2D boundary of the selected object
ZCoordinate(criteria)
The z coordinate of the insertion point for symbols, point plug-in objects, and loci. The returned value is relative to the user origin. Related functions: XCoordinate, YCoordinate, ZCenter
Example:
●       Database header cell: =ZCoordinate returns the z coordinate value for each object in the database
