Creating revision clouds
Tool
Tool set
Revision Cloud
Dims/Notes
Use the Revision Cloud tool to identify a section of a drawing that has changed. Insert a revision cloud in an area of the drawing, or around an entire portion of the drawing, if appropriate.
For the Vectorworks Design Suite products, revision clouds can also be created by first drawing a closed 2D shape and then selecting the Create Objects from Shapes command (see Creating objects from shapes).
Mode
Description
Oval
Inserts the revision cloud around the perimeter of a preview oval. Click to set the start point, move the cursor in the desired direction, and click to set the end point.
Rectangular
Inserts the revision cloud around the perimeter of the preview rectangle. Click to set the start point, move the cursor in the desired direction, and click to set the end point.
Regular Polygon
Inserts the revision cloud around the perimeter of the specified vertices. Click to set the start point (first vertex), click at the desired location for each subsequent vertex, and either click at the starting vertex to close the polygon or double-click at the final vertex to create an open polygon. If the polygon is open, the cloud is completed based on the outline.
Freehand Polygon
Inserts the revision cloud around the perimeter of the specified vertices. Click to set the start point and click-drag to draw the freehand polygon. If the polygon is open, the cloud is completed based on the outline.
Convex Shape
Draws the cloud billows outward from the shape you draw
Concave Shape
Draws billows inward from the shape you draw
Preferences
Sets the default parameters for the tool
To create a revision cloud:
Click the tool and mode.
Click Preferences to open the Revision Cloud Properties dialog box and set the tool’s default parameters. The parameters can be edited later from the Object Info palette.
Click either Convex Shape or Concave Shape mode.
Click to draw the revision cloud in the desired shape.
Parameter
Description
Billow Size
Select the relative billow size from extra small to extra large, or on the Object Info palette select Custom to specify a billow size
Billow Radius
For a custom billow size, sets the billow size
Billow Variability
Select the variability (the variation between the smallest and largest billows)
Billow Height
Select the relative billow height (small, medium, or large)
Billow Type
Select a convex or concave billow type
Vertex Parameters
Edits the revision cloud vertices; see Editing vertex-based objects
The following illustration demonstrates the effects of varying the billow size and billow variability parameters.
