Repeating commands
Repeating the last command
Command |
Path |
Shortcut |
Repeat [last command] |
Edit Context menu |
R |
The Repeat [last command] command enables you to use the most recent command. After you use a menu command, Repeat is followed by the command name (for example, Repeat Rotate).
If no commands have been used in the session, this command is named Repeat Last Command and is grayed.
To repeat the last command:
Select the command.
If executing the command typically opens a dialog box, repeating it opens the dialog box with the most recent settings. If there is no associated dialog box, the command is executed immediately.
The shortcut key to repeat the last command can be customized; see Modifying special shortcuts.
Repeating recent commands
Command |
Path |
Recent Commands |
Edit Context menu |
The Recent Commands command displays a maximum of the ten most recently used commands.
To repeat a recent command:
Select the command.
The command history opens.
Select a command from the command history. The most recently used command is displayed at the top. Commands that cannot be executed with the current selection are grayed.
Clearing the last command and the command history
The following actions clear the last command and the command history:
Closing Vectorworks
Changing workspaces
Clicking Reset in the Vectorworks Preferences dialog box
The following actions do not clear the last command or the command history:
Creating, opening, or closing a file
Switching to a different file
Excluded commands and menus
The following commands cannot be repeated.
Menu |
Excluded commands |
File
New All Open commands All Close commands All Save commands All Revert commands Quit |
Edit
Undo Redo Cut Copy Paste Paste In Place |
Text
Font Size Font Style Alignment Spacing Capitalization |
Window |
All menu commands |
Help |
All menu commands |
Commands on the following menus cannot be repeated:
Quick Preferences menu
Some context menus (for example, a list browser menu)
Utility menus
