Saving working plane positions
The working plane position can be saved with the drawing and accessed later from the Working Planes palette or Planes list on the View bar.
To save a working plane position:
Click the Utility menu on the Working Planes palette's title bar.
Alternatively, right-click on the palette to access the context menu.
Select the New command.
Alternatively, select Modify > Working Plane > Save Working Plane or right-click on the drawing to access the context menu.
The New Working Plane dialog box opens. If there is a currently active working plane, the dialog box displays the plane's origin and rotation values. Otherwise, the origin and rotation values of the layer plane display.
Name the working plane position and reset the values, if desired.
Saved working plane positions are displayed in alphabetical order in the palette. To access a saved working plane position, double-click its name in the Working Planes palette or select it from the Planes list on the View bar.
