SmartCursor cues
The following table lists the individual cues that the SmartCursor uses along with a description of each. In many cases, two cues are used together to indicate that two snaps have been activated. For example, the cue ‘Align H/Angle’ means that the point located is both aligned horizontally to the indicated smart point and also snapping to an angle.
Some cues display when a first point has already been found, and a second point is being sought. These two points form a line called the feedback segment. This segment forms an angle and length which the SmartCursor uses for some of its snaps.
When other snap points are nearby, an icon displays to the left of the SmartCursor cue text to alert you. Zoom in or use the snap loupe for a close enough view to select the desired snap point.
For a line, the feedback segment is the same as the line being drawn. However, for other objects, the interactive image does not lie on the feedback segment. The SmartCursor works on the feedback segment created from the first to the second points (for polygons, from the previous point to the current point).
Cue
Description
Snap to Angle
Alt
Feedback segment is parallel to the alternative coordinate system angle
Alt 90°
Feedback segment is perpendicular to the alternative coordinate system angle
Delta angle
Feedback segment is at the specified snap angle from the rotated grid
Horizontal
Feedback segment is horizontal
Parallel
Feedback segment is parallel to an object
Perpendicular
Feedback segment is perpendicular to an object
Plan Rotation
(Design Suite required)
Feedback segment is aligned to the rotated plan angle
Symmetric
Feedback segment is sketching out a square or circle
Vertical
Feedback segment is vertical
X
Feedback segment is aligned with the X axis
Y
Feedback segment is aligned with the Y axis
Z
Feedback segment is aligned with the Z axis, or point is aligned to a smart point in the direction of the Z axis
X’
Feedback segment is aligned with the X axis of the rotated grid
Y’
Feedback segment is aligned with the Y axis of the rotated grid
Z’
Feedback segment is aligned with the Z axis of the rotated grid, or point is aligned to a smart point in the direction of the Z axis of the rotated grid
Smart Point
Extension line used for all smart point cues except Datum
Align
Feedback segment is perpendicular to a segment from the cursor to a smart point
Align H
Point is aligned horizontally with a smart point
Align V
Point is aligned vertically with a smart point
Align X
Point is aligned with the X coordinate of a smart point
Align Y
Point is aligned with the Y coordinate of a smart point
Align Z
Point is aligned with the Z coordinate of a smart point
Align X’
Point is aligned with the X coordinate of a smart point, in the space of the rotated grid
Align Y’
Point is aligned with the Y coordinate of a smart point, in the space of the rotated grid
Align Z’
Point is aligned with the Z coordinate of a smart point, in the space of the rotated grid
Align Edge
Point is aligned to smart edge
Align Edge 90°
Point is aligned perpendicular to smart edge
Align Alt
Point is aligned to the user coordinate system
Align Alt 90°
Point is aligned perpendicular to the user coordinate system
Datum
Point is the Datum
O
Circle around Datum
Working Plane
Point is on the grid plane
Snap to Distance
Along Line
2D Point is at a specified distance along line
3D Point is at a specified distance along line from the end point of a NURBS curve, 3D polygon, or edge of a solid object
Data bar
Extension line used to indicate X or Y value is locked
Angle
Feedback segment is constrained to an angle
Length
Feedback segment is of a fixed length set in Data bar
Snap to Object
Arc
Cursor is over the corner point of a polyline arc segment
Arc Center
Cursor is over the center point of an arc
Arc End
Cursor is over the end of an arc segment
Bézier
Cursor is over the corner point of a polyline Bézier segment
Bottom Center
Cursor is over the bottom center of rectangle or group
Bottom Left
Cursor is over the bottom left of the object’s bounding box
Bottom Right
Cursor is over the bottom right of the object’s bounding box
Center
2D Cursor is over the center of the object’s bounding box
3D Cursor is over the geometric center of certain objects, NURBS curves, 3D polygons, or the center of a circular NURBS curve
Center Left
Cursor is over the center left of the object’s bounding box
Center Right
Cursor is over the center right of the object’s bounding box
Corner
Cursor is over the corner point of a polyline segment
Endpoint
Cursor is over the end of an object’s edge
Fit
Cursor is over the corner point of a polyline cubic segment
Internal Origin
Cursor is over the file’s internal origin marker
Insertion Point
Cursor is over the object origin for symbols, parametric objects, and text objects; for dimensions, the cursor is over one of the referenced points
Light
Cursor is on a light
Locus
Cursor is on a locus
3D Locus
Cursor is on a 3D locus
Midpoint
Cursor is over the middle of an object’s edge
Object
2D Cursor is on an object’s edge
3D Cursor is on any non-specific point along a solid edge or NURBS curve; displays at all corner points when the Nearest Point on Edge option is deselected for object snapping
Page
Cursor is over the page boundary
Page Bottom Center
Cursor is over the bottom center of the page boundary
Page Bottom Left
Cursor is over the bottom left of the page boundary
Page Bottom Right
Cursor is over the bottom right of the page boundary
Page Center
Cursor is over the center of the page
Page Center Left
Cursor is over the center left of the page boundary
Page Center Right
Cursor is over the center right of the page boundary
Page Top Center
Cursor is over the top center of the page boundary
Page Top Left
Cursor is over the top left of the page boundary
Page Top Right
Cursor is over the top right of the page boundary
Point
3D Cursor is on one of the vertices of a solid, the control point of a NURBS curve, the control point of a NURBS surface, or NURBS curve interpolation point
Top Center
Cursor is over the top center of the object’s bounding box
Top Left
Cursor is over the top left of the object’s bounding box
Top Right
Cursor is over the top right of the object’s bounding box
Smart Edge
Bisector
Point is on the bisector between two smart edges
Edge
Feedback segment is parallel to a smart edge, or cursor is on the edge between two smart points
Edge 90°
Feedback segment is perpendicular to a smart edge
Offset
Point is a preset distance from a smart edge
Smart Edge
Point is on a smart edge, but not on the object itself
Snap to Tangent
Tangent
Feedback segment is tangent to an arc
Tangent/Tangent
Feedback segment is tangent to two arcs
Setting snapping parameters
Drawing with snapping
