Constrain horizontal-vertical
Tool |
Tool set |
Constrain Horiz-Vertical
Dims/Notes |
Multiple geometric constraint tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
Constrain a linear object to remain horizontal or vertical. Once constrained, the object cannot be rotated to any other position. The object can be resized in length, but it always remains horizontal or vertical.
To constrain an object to remain horizontal-vertical:
Click the tool.
Click the linear object to be constrained.
A green horizontal-vertical constraint is drawn on the object.
If the object is diagonal when the constraint is placed, it rotates to become vertical or horizontal (whichever is closest).
