Adding loads
             Tool  |
             Tool set  |
             Rigging Load
             Rigging  |
Many Spotlight objects are automatically considered to be either a point load (such as lighting devices and projectors) or a distributed load (such as soft goods, video screens, and LED screens). A generic point load or distributed load can be added with the Rigging Load tool. See Concept: Attaching loads to rigging objects.
After placement, the generic load symbol can be switched to use a realistic graphical symbol instead.
             Mode  |
             Description  |
             Point Load
             Inserts a point load  |
             Distributed Load
             Inserts a distributed load  |
             Load Category  |
             Specifies the load category, which is important for calculations (Braceworks required)  |
             Weight  |
             Sets the weight of the load. For a point load, this value is the total weight. For a distributed load, this value represents either the distributed weight or the total weight, depending on the selected weight mode.  |
             Non-Rotated Label
 (point load only)  |
             Does not rotate the label text  |
             Perpendicular Label   (point load only)  |
             Angles the label text 90 degrees from the rigging object  |
             Angled Label
 (point load only)  |
             Angles the label text 45 degrees from the rigging object  |
             Distributed Weight
 (distributed load only)  |
             For distributed loads, the specified Weight represents the distributed weight  |
             Total Weight
             For distributed loads, the specified Weight represents the total weight  |
             Load Settings
             Opens the Load Settings dialog box, for creating and selecting saved load sets  |
