Clearing calculation results
Command |
Workspace: Path |
Clear Calculation Results |
Spotlight: Customize workspace to add command (see Customizing workspaces) Braceworks: Braceworks |
The results from the most recently executed calculation (Braceworks required) or system check command are retained and display in the Calculation overview dialog box. These results can be cleared with the Clear Calculation Results command.
To clear calculation results:
Select the command. All calculation results and any resulting issues are cleared. Any issue labels in the drawing are removed, and any color coding of hoist labels reverts to red.
