Connect04328.pngAdding a rack ruler
Tool
Tool set
Rack Ruler
Layout
The rack ruler measures the height of equipment racks by placing a 2D ruler on the drawing with both drawing unit and rack unit markings. The ruler measurements are displayed in the units specified in the document settings (see Units settings: Dimensions pane).
To place a rack ruler:
Click the tool.
Click Preferences to specify the tool’s default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Height (RU)
Sets the height of the rack ruler in rack units
Base Offset
If the rack ruler measurements should be offset from the base of the equipment rack, enter the offset value
Click once to place the rack ruler; click a second time to set the rotation.
Placing equipment racks
Creating layouts
