Connect04252.pngBuilding a device
Tool
Tool set
Device Builder
Schematics
The device builder allows you to select and place a standard manufacturer device, or create and then place your own device.
If you know the make and model number of a manufacturer’s device, the device builder automatically adds the appropriate sockets and other information.
If you do not know the make or model number, or if you want to modify a standard device, the device builder is still a convenient way of creating a custom device with sockets. The custom device can be created from scratch, or based off of an existing device.
If you only create custom devices, disable the Enable database option in the device builder preferences so that you do not need to scroll through existing make and model information.
Custom devices created with the device builder are automatically saved as symbol definitions in the user folder. These can be accessed for editing from the Resource Manager, and they can be placed on the drawing with the Insert Device mode of the Device tool. If you click Create Temporary Device, the symbol definition is not saved in the user folder.
To delete a custom device, select it from the Make/Model list in the device builder, and then click Delete (trash can). This prevents temporary or unused devices from cluttering up the Make/Model list.
To insert a device with the device builder:
Click the tool.
Click Preferences on the Tool bar to set the default settings.
The Device Builder Preferences dialog box opens.
Parameter
Description
Device Appearance
Mininum Width (Grid Spaces)
Sets the minimum width of the device in grid units
Space at Top of Device (Grid Spaces)/Space at Bottom of Device (Grid Spaces)
Adds space at the top and/or bottom of the device; set the space in grid units. This can help space out devices in a complex drawing and keeps the drawing neat.
Socket Group Spacing (Grid Spaces)
Sets the space between sockets in grid units
Device Database
Enable database
Allows you to select from the database of existing makes and models when building the device. If you only build custom devices, deselect this option so that you can specify custom information.
Click to place the device.
The Device Builder dialog box opens. Enter information about the device and its sockets.
Parameter
Description
Device Browser
Category/Device type
Select the category of device, and click the disclosure arrow to select a device type. Enter text in the search box to filter the list.
This selection filters the Make/Model list. Alternatively, select <All> to view all makes and models.
Make/Model
Select the manufacturer, and click the disclosure arrow to select the model name from the list. The available items shown in the list depend on the selection in Category/Device Type. Enter text in the search box to filter the list.
If the model, or even the manufacturer, is not available, you can customize the device. To create a custom make and model, select New Make/Model to open the New Make/Model dialog box. Either select a manufacturer, or select New Make. Enter the custom make name, and then specify the model name. Select a Category for the device; in some cases, this determines which tool can place the device later. For example, a category of Distribution Amplifier means that the customized device can be placed with the Distribution Amplifier tool.
The new make and model appear in the Make/Model list under your user name for future selection.
If Enable database was not selected in the preferences, the Make and Model are blank so that you can enter custom information.
Delete (trash can)
Deletes the custom device that is selected from the Make/Model list, removing it from the user folder
Device Identification
Enter information that appears in labels on the drawing and in worksheets
Device Name
Enter the name of the device
Display Tag
Enter the tag name for labels (normally, this is the Device Name)
Display Description
Enter a description, such as the manufacturer and model name
Label Symbol
Select a label symbol definition; advanced users can edit the label from the Resource Manager
Device Type
Physical
Creates a device that can automatically create a corresponding equipment item in the layout with the Create Equipment command
Virtual
Creates a virtual device; this is not considered as a device for creating equipment items automatically in the layout
Height/Width/Depth
Enter the device height, width, and depth in millimeters
Height (Rack Units)
Enter the height in rack units
Half-rack width
Sets the width to half of a standard 19” rack (9.5” or 242 mm)
Modular device
Indicates that the device is modular and is inserted in a rack frame
Module Width (Frame slots)
For modular devices, enter the number of frame slots required in a rack frame
Power
Specify the power requirements (the units are set in the ConnectCAD Settings)
Weight
Enter unit weight (the units are set in the ConnectCAD Settings)
Sockets Definition
If the manufacturer’s make and model information was recognized by ConnectCAD, the sockets are defined for you.
To customize, specify the number of in, out, and I/O sockets for each type of signal and connector to be created on the left and right sides of the device. Generally, inputs (and I/O) are located on the left, and outputs (and I/O) are located on the right.
Sockets are added to the device in row order; the rows can be rearranged by clicking and dragging in the # column.
Click in the Use column to include or exclude the socket.
Add/Delete
Adds sockets to the device, or deletes the currently selected socket row
Instead of clicking OK, click this option to create a device that is for one-time use only and is not saved in the user folder
Do one of the following:
Click OK to add the device as a resource in the user folder, where it can be used later in other files
Click Create Temporary Device to create a device for use only in the current file
If you change your mind and want to save a temporary instance, click Save as Symbol from the Object Info palette of a selected device, to save the device as a symbol definition resource.
Placing a basic device or device symbol
Placing specialized devices
Adding sockets, loops, and terminators
Editing devices and sockets
Placing devices
Creating devices from a worksheet
Creating equipment items automatically
ConnectCAD
