Connect04321.pngCreating a layout room
Mode
Tool
Tool set
Rectangle
Polygon
Layout Room
Layout
The layout room is an optional 2D container for equipment racks. 2D racks placed within the boundary of the room will inherit the Room ID parameter as a read-only parameter denoting location.
To create a layout room, either use the Layout Room tool, or create a closed 2D shape and then select the Create Objects from Shapes command (see Creating objects from shapes).
To create a layout room:
Ensure that the current design layer is Rack Elevation.
Click the tool and select a drawing mode.
Do one of the following:
In Rectangle mode, draw the rectangular room shape, similar to drawing a rectangle in Corner to Corner mode.
In Polygon mode, draw a closed polygon shape.
Place polygonal layout rooms on architectural floor plans to define the location of non-rack equipment.
In the Object Info palette, provide the Room ID.
Edit the layout room by double-clicking on it and using the Reshape tool.
Placing equipment racks
Creating layouts
