Connect04323.pngPlacing a rack frame
Tool
Tool set
Rack Frame
Layout
A rack frame is placed within a rack and it becomes associated with the rack, inheriting the rack’s ID/location and moving along with it. Rack frames are used for modular equipment items. A rack frame can optionally be inserted stand-alone.
To place a rack frame:
Click the tool.
Click to place the rack frame in the drawing; normally, place the rack frame within an equipment rack. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
General
Name
Enter a rack frame name for labels and reports
Manufacturer
Make/Model
Enter the manufacturer’s make and model information
Physical
Mounting
Select whether the rack frame mounts to the front or rear of the equipment rack (useful for 3D views)
Height RU
Select the height of the frame in rack units
Depth/Power/Weight
Specify the rack frame’s size, power requirements, and weight
Configuration
Slots H/V
Enter the number of slots in the frame, in the horizontal and vertical direction
Power Supplies
Select the number of power supplies in the frame
PSU Location
Select the location of the power supply units
PSU Size
Enter the size of each power supply unit
Location
Displays the containing layout room and equipment rack ID, as well as the rack location in rack units
Creating layouts
