DesignSeries05984.pngAutomatically creating record formats from a database table
Command
Path
Manage Databases
Tools > Database
Record formats can be created from database tables. The imported tables are automatically linked to the new record formats.
To create record formats from a table in a connected database:
Select the command.
The Manage Databases dialog box opens.
Select the database on the left, and then click Import Table.
The Import Table dialog box opens.
Parameter
Description
Database Table Name
Displays the name of the selected database
New Record Format Name
Specifies the name of the new record format to create; the suggested name is based on the database table name, but it can be changed
New Record Format Fields connection
Lists the database columns and the corresponding record field and type; database fields with a check mark in the left column become record fields in the Vectorworks file
Selection
Specifies the parameters and link type for the selected record field to be created; the Record Field Name, Record Field Type, and Database Link Type are suggested based on the column information, but they can be changed
Select the columns from the database that will become record fields in the new record format by placing a check mark in the left column. For each selected column, specify the record field name, type, and connection type. For more information on connection types, see Record format database connection.
Each selected table column in the database table becomes a record field in the new record format. The record fields are automatically connected to the database according to the connection type specified.
Automatically creating a database table from a record format
Specifying update settings
