Hole pattern
Mode
Tool
Tool set
Hole Pattern
Detailing
To insert a hole pattern:
Click the tool and mode.
Parameter
Description
Pattern
Select a hole pattern
Number of Rows
For rectangular hole patterns, enter the number of rows
Vertical Spacing
For rectangular hole patterns, enter the vertical spacing between the rows
Number of Columns
For rectangular hole patterns, enter the number of columns
Horizontal Spacing
For rectangular hole patterns, enter the horizontal spacing between the columns
Number of Holes
For bolt circle patterns, enter the number of holes
Bolt Circle Dia.
For bolt circle patterns, enter the diameter
Hole Type
Select the type of holes
Hole Size
For round and tapped hole types, enter the hole size
Slot Width
For slotted hole types, enter the slot width
Slot Length
For slotted hole types, enter the slot length
Counterbore/Countersunk
Draws counterbore or countersunk holes
Diameter
Indicates the diameter of the counterbore or countersunk holes
Show Centerlines
Displays the centerlines on the pattern
View
Select the hole pattern view
