J-bolts
Mode
Tool
Tool set
J-Bolt
Fasteners
The J-Bolt tool and J-Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a J-bolt:
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Size
Specify the J-bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Length
Specify the bolt length
Thread Length
Specify the thread length
Bend Radius
Specify the radius of the bend
Anchor Length
Specify the anchor length
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
Add Nut
Draws the J-bolt with a hex or square nut; click the control point to adjust the nut placement graphically and click again to place the nut
Add Lock Washer/Washer
Draws the J-bolt with a lock washer and/or with a narrow, regular or wide washer
Bearing Length
Specify the bearing length; if a nut or washer is added or removed, the bearing length remains constant and the position of the existing objects is adjusted accordingly (if the nut or washer is moved, the bearing length is not automatically adjusted)
Show Threads
(3D only)
Draws the J-bolt with threads
Anchor to the right
(2D only)
Draws the J-bolt with an anchor to the right or deselect to draw the anchor to the left
Show Center Line
(2D only)
Draws the J-bolt with center line(s)
Inserting fastener objects using the Fastener tool
Bolts
