T-bolts
Mode
Tool
Tool set
T-Bolt
Fasteners
The T-Bolt tool and T-Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a T-bolt:
Click the tool and mode.
Parameter
Description
Size
Specify the T-bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Head Size
Specify the T-bolt head size
Head Thickness
Specify the T-bolt head thickness
Length
Specify the length under the bolt head
Thread Length
Specify the thread length
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the T-bolt with center line(s)
Show Threads
(3D only)
Draws the T-bolt with threads
Inserting fastener objects using the Fastener tool
Bolts
