Wood screws
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Detailing |
The Wood Screw tool and Wood Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a wood screw:
Click the tool and mode.
Parameter |
Description |
View (2D only) |
Select the 2D view
Series |
Select inch or metric to display the appropriate nominal sizes |
Head Type |
Select the wood screw head type
Nominal Size |
Select an inch or metric nominal size |
Length |
For a custom length value, deselect Use Standard Length Increments and enter the length under the screw head (or overall length for flat head screws) |
Slot Type |
Specify the slot type
Use Standard Length Increments |
Automatically adjusts the length to the nearest increment based on size; deselect to enter a custom length |
Show Threads |
Draws the wood screw with threads |
Show Center Line (2D only) |
Draws the wood screw with center line(s) |
