Retaining washers
Mode
Tool
Tool set
Retaining Washer
Fasteners
Multiple retaining ring and retaining washer tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a retaining washer:
Click the tool and mode.
Parameter
Description
Groove Size (mm)
Select the retaining washer groove size in millimeters
View
(2D only)
Select the 2D view
Place Locus at Center
Adds a locus at the center of the retaining washer
Retaining rings
